Released on 2017/5/25 (CST / UTC +8), model MDE40.
2 Questions View all
Problem booting up Xiaomi Mi Max 2
Hi all, So the phone does not turn on or show any sign of life while unplugged, not even the notification led lights up.
- When i plug it in, the "mi" logo appears for a second and then it turns off.
- When i try booting it into recovery mode (while plugged in), the "mi" logo appears, phone vibrates and then it turns off.
- When i try entering fastboot while plugged into the outlet, fastboot appears for a second, screen goes black but the notification led keeps blinking.
- When i try entering fastboot while connected to the PC, fastboot screen appears for at least 30 seconds, USB malfunctions and the device is not recognized (Trying MiFlash tool latest version.)
- I also tried using several other chargers and a power bank, It usually draws power for a minute or so as though it's charging and then it stops.
The cause of this issue is most likely water damage (The phone is in a pristine condition, never been dropped or mechanically damaged).
So what could be wrong with the phone and what could i do to fix it?
Any thoughts or comments are appreciated.
3 Comments
i have same problem it screen got damage due to large size i change it again this happen
by
It's from the battery most probably, I changed mine and it was fixed and booted up.
by
@Nitya Nair ?
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
If you suspect water damage then presumably the phone has gotten wet at some time. Is this correct?
If so, then the only way to verify if there has been water damage or not is to open the phone and visually inspect the internal components to see if any water damage has occurred.
I also recommend that you stop connecting the charger to the phone until it has been inspected.
Normally when an electronic device has been affected by water the first thing to do is to disconnect and remove all sources of power, i.e. the internal battery and external sources, to minimize any further damage.
Here’s a link to the ifixit Electronics Water Damage guide which may be of some help.
Here’s a link to a video that shows how to replace the battery in the phone. I realize that this is not the problem but the video is useful as it shows how to open the phone so that it can be inspected.
There are other videos on YouTube that show how to replace the screen etc, on you model phone which may also be of some help in gaining access to the various parts of the phone.
If doing this seems too daunting a task, contact a reputable, professional mobile phone repair service (preferably experienced in liquid damage repair) and ask for a quote to repair the phone.
Score 2
Add a comment
Add your answer
7skies will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,900
