Flagship smartphone from Huawei released April 2018. Model CLT-L29.
56 Questions View all
My P20 Pro only has service when plugged into a charger.
I took my phone to a repair shop as i completely smashed my screen.
He managed to replace the screen but now my phone will only connect to Vodafone network when plugged into a charger.
If i remove the usb from the charging port it goes to no service
Score 4
Add a comment
1 Answer
Most Helpful Answer
Sounds like the battery may have gotten disconnected and/or died.
Huawei P20 Pro Battery Replacement
Score 1
3 Comments:
Changed the battery and still the same issue. Replaced the Antenna as well. Any other suggestions?
by
@jayb_1991
I'm facing the same issue after replacing my battery's
were you able to solve your issue ?
by
Hi, same problem for me. After battery replacement, signal is ok only under charging or if I connect hear jack. Any suggest?
by
Add a comment
Add your answer
jayb_1991 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 583
