0
Score
Avatar
les
Asked
LCD leak bezel or lcd itself?
History
My Powerbook's screen is leaking pretty badly at the bottom to the point it's distracting. Is the problem with the bezel or the lcd itself? Which do I need to replace?
Thanks, I meant light leak on the surface of the lcd itself. I assume the fix is the same -- a new panel. Thanks.
les,
Post Answer
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
There's nothing in the bezel to leak. This sounds like you've cracked your screen. Here's how to replace it: Installing PowerBook G4 Aluminum 12" 1-1.5 GHz LCD
Here's the part that iFixit has. I would look at the back of your screen and contact them to make sure the replacement will work.
G4 Aluminum 12" LCD Panel
Product Image
LCD without the display bezels, hinges, or cables / 1024x768 / 12.1" — 3 available at 199.95 each.
Add Your Answer
