Entry level Photosmart printer introduced in 2009. Uses HP Tri-Color ink cartridges with a disposable printhead.
14 Questions View all
How to make copies with only black ink cartridge installed
My friend has this printer and she can print with just the black ink cartridge installed. But when she tries to use the copier function, she can’t cancel the error message indicating that no color ink cartridge is installed. “OK” is not lit up so you can’t select it and cancel the error message to select the copy option. Can this printer make copies with only the black ink cartridge installed? Thanks for any suggestions.
Score 1
Add a comment
1 Answer
Chosen Solution
try to log in to the printer settings on the computer and edit the copy settings
Score 1
1 Comment:
Keith, thanks for your suggestion. We’ll try it.
by
Add a comment
Add your answer
Rick Crume will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 144
