Repair and disassembly guides for Kenmore Microwaves.
182 Questions View all
Microwave shuts off intermittently, already replaced door switch assem
I have a model 401.80082700 serial 725MM00044. Intermittent problem. Microwave goes through heating cycle and then totally powers off…no display, no light, no power. After 15-30 seconds the display comes on and instructs to press clock and reset time of day. After doing so the microwave is fully functional and may operate several times before powering off again. Occasionally the display appears fainter than normal, esp the center of display. I have replaced the door switch assembly but after several days the intermittent problem has returned. What do you think? TY
Score 3
1 Comment
After much delay and frustration I ordered and replaced the control board…..works great…..thanks for your recommendation!
by
Add a comment
Chosen Solution
Sounds like the problem is the control board, not the door assembly. Try replacing the main controller circuit.
Good luck!
Score 1
1 Comment:
I have the same problem with my Kenmore microwave. Is this the part I need? https://www.searspartsdirect.com/product...
by
Add a comment
Most Helpful Answer
There are two parts to that door switch, here they are on your model along with how to test them:
https://www.repairclinic.com/RepairHelp/...
Score 2
Add a comment
Add your answer
Ken Thome will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 10
Past 30 Days: 17
All Time: 1,044
