Kenmore 90 series washer model 11020902991
My washer fills and agitates the stops working. What do I need to do. I am normally not a fixit guy but am looking for answers
https://www.repairclinic.com/RepairHelp/...
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Lid Switch Assembly for your Kenmore Washing Machine
RepairClinic Item #4248251
Washing machine lid switch assembly with wire harness. The lid switch ensures that the washer door is closed while the washer is spinning. If the lid switch is broken, the washer will not spin. If the washer won't spin but will still agitate, the lid switch is likely defective.
$26.11
Total: $26.11
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Parts
Motor Coupling for your Kenmore Washing Machine
RepairClinic Item #1195967
Washer drive motor coupler. New style with metal sleeves for added strength. This version replaces all previous motor coupler styles and versions. For direct drive washing machines. Common symptom of failed coupler is washer will fill, not agitate or spin but will drain the water from the tub.
$11.63
Cause 3
Clutch
The clutch assembly makes the connection between the transmission and the inner tub. It helps the tub to gradually get up to the proper spin speed. If the clutch is worn out, it may prevent the tub from spinning. The clutch is not repairable—if the clutch is worn out, replace it.
Parts
Clutch for your Kenmore Washing Machine
RepairClinic Item #2670
Washing machine clutch assembly with hardware. *Blue spring for large capacity washers, black for compacts. A worn clutch often causes a slower spin speed which leaves the clothes soaked after the cycle.
$24.49
Suggested toolsMulti ScrewdriverRepairClinic Item #3527472$14.73PliersRepairClinic Item #3527486$25.53PliersRepairClinic Item #3527549$19.99
how do you get broken bolts off the trans on a 90 series Kenmore washer
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 857
1 Comment
I want manul panal90 series
by Tayyaba Naz
