1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Can I mount a Samsung 970 EVO PLUS?
Hello, I have a Samsung 970 EVO PLUS m2 drive and I’d lik to know if a compatible adapter exists for my Mac! I already tried this but i can’t connect the ssd to it
https://m.imgur.com/gallery/buQOeYi
Any clues? Thanks
2 Comments
Sadly on this specific model there are no good solutions as all the Toshiba SSDs go bad on the mid 2012 airs.
by
I would install either the OWC or Transcend SSD instead.
by
Add a comment
1 Answer
Chosen Solution
Your MacBook Air uses a custom Apple connector system. M.2 SSD’s won’t fit directly and I don’t recommend using M.2 adapters as I’ve had to replace quite a few setups with the correct SSD as the M.2 SSD tend to burn out from the heavy CRC errors they encounter in this config. Yes, they look like they work but over time they fail!
You also have a second issue here which is what the system can support for a SSD. There are three different interfaces
Lets review what your system uses here The Ultimate Guide to Apple’s Proprietary SSDs - Gen 2 So your system only uses the Red mSATA interface on the left.
So the Samsung970 EVO Plus is just not compatible!
Score 2
2 Comments:
so which ssd you recommend for upgrading a macbook air 2017 (A1466)?
by
I would go with either OWC or Transcend SSD's or stick with a larger Apple SSD BeetsTech
by
Add a comment
Add your answer
tyronefromhell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 3,946
