Repair guides and support for top and front loading Whirlpool brand washers.
428 Questions View all
Whirlpool Washer water is always hot
We were given an older whirlpool washer. We replaced the hoses when we hooked up the machine. The water is always hot. There is water being pulled from both the hot and cold hoses. If I set the washer to COLD it stops, nothing happens. If I set it to COOL nothing happens. If I set it to WARM it will start filling and then I can switch it to COOL, but regardless it is always hot water even if it is pulling from both hoses.
This Whirlpool is older and it doesn’t have a computerized screen or anything.
Does anyone happen to know what is going on? Because of this issue we went through 100 gallons of oil in 2 months, which is really bad for us. I really want a way to wash in cold water. It has come to a finacle point that is is cheaper to go to a laundry mat or someones home than use our oil to wash clothes. 5 kids here, really need a working washer!
Add a comment
1 Answer
Chosen Solution
Water inlet hose filter is probably clogged up. Here’s a video on how to fix it:
https://www.youtube.com/watch?v=kVBbFF5G...
Score 2
4 Comments:
Its not the inlet hose. I have the same problem. It washes on hot when i put it on hot, washes on hot when i put it on cold. my hoses are not crisscrossed. If it did not fill when its set to cold i would understand, but it fills with hot water on both settings. Its not connected to two hot water lines. is there a temp sensor in these machines? is that whats wrong?
by
@firefly032f
What is the model number of your washer?
by
I have the exact same problem
by
@triq
by
Add a comment
Add your answer
lilybecstanleybrawlmum will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 154
All Time: 7,456
