Repair guides and support for top and front loading Whirlpool brand washers.
426 Questions View all
Whirlpool washing machine wont agitate on large loads only
Good day, i have a top loader whirlpool machine model 1cwtw4800yq0, on large loads the machine just fills with water , starts agitating for 3 seconds then stops, however when machine is used for medium an small loads works fine, any help would be appreciated, thank you
Score 1
1 Comment
I have a Kitchenaid top loader that works great until I do an extra large load. It fills with water but will not agitate. Agitate works on all other load sizes! On extra large sometimes it just sits silent after filling until the timer gets to drain and spin it then refills for the rinse cycle which is again hit or miss if it will agitate. I have found that when this is happening if I lift the full barrel from the inner sides and turn it slightly the motor kicks on and it starts agitating as it should. Lifting some of the weight of the load and turning the barrel a little makes it work? Is there some kind of pressure switch? Small medium and large loads always work fine. Thanks for any help.
by
Add a comment
Chosen Solution
Large loads put a strain on the motor. There can be lots of causes but these three are the most common.
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Score 2
4 Comments:
For all three of these solutions the motor would be clearly heard running. What if it just sits silent as the timer runs to the next cycle???
by
@mark60365
What is the model number of your washer?
Does the problem only occur on large loads, as asked in the original question or the load size doesn't matter?
by
I have a Kitchenaid Extra Heavy Duty Plus top loader that works great until I do an extra large load. It fills with water but will not agitate. Agitate works on all other load sizes! On extra large sometimes it just sits silent after filling until the timer gets to drain and spin it then refills for the rinse cycle which is again hit or miss if it will agitate. I have found that when this is happening if I lift the full barrel from the inner sides and turn it slightly the motor kicks on and it starts agitating as it should. Lifting some of the weight of the load and turning the barrel a little makes it work?
by
So I took it apart last night to see if I could figure it out and I think I did. The connector that plugs into the motor had burn marks from inside the connector on the lower 2 pins. Obviously intermittent connections that where arcing. I took the connector apart and cleaned everything up, bent the sockets in a little so there was a good friction fit with the mating pins and so far after a couple XL loads all is good. I'm glad I caught it before it started a fire in the connector.
by
Add a comment
I replaced the motor couplers lid switch dog agaitor clutch assembler and washing still buzzing it’s a kenmore 70 series what could be the problem
Add a comment
Add your answer
jimmy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 3,015
