0
Score
Avatar
Hrvoje
Asked
LCD Backlight not working if battery over 80% charged
History
I have a rather unique problem i have cracked an replaced the lcd + digitizer the problem appears both with the cracked LCD and a new one so i am assuming i messed up something on the board itself
THE LCD BACKLIGHT IS NOT WORKING WHEN CHARGED OVER 80% go figure
Can anyone help?
Weird. Never hurts to try a Reset. Hold together Home and Power buttons for about 15 seconds, let iPhone turn off itself and then it will turn back on.
Brad,
Post Answer
0
Score
Avatar
Richdave
5.1k
Answered
PermalinkHistory
It may be a heat related issue - check for loose connections. Does the battery look swollen? It may be expanding a little when hot?
If not then you may need to replace the display
iPhone 3GS Display
iPhone 3GS Display Assembly
Edited by
Product Image
iPhone 3GS Display
LCD panel / Does not include touch portion of display or the metal backing plate. — 6 available at 69.95 each.
Product Image
Includes touchscreen glass, integrated digitizer, LCD, ear piece speaker and home button. Does not work in... — 42 available at 99.95 each.
Product Image
iPhone 3GS Replacement Battery
Does not require soldering. — 50+ available at 19.95 each.
Add Your Answer
