I read there are CPU upgrade options on one article, which ones fit?
Which CPU upgrades are possible? I’m assuming it is not soldered onto the motherboard, because the article I read, said it could be done.
Laptops & Tablets tend not to offer CPU chip upgrades as the thickness of the system would suffer with the added height of the socket.
You might find a replacement logic board is an option if HP offered up a version with either more memory or a higher clocked CPU.
Reviewing the spec sheet for your system this system uses an Intel 1.8 GHz Adam Z2760 CPU with 2 GB of RAM and is the only configuration HP offered so there is no logic board swap-out option.
Silly, that article was mistaken! upon further research, you are correct there. However, there are true windows tablets that offer upgrade-ability, though few and far between.
Thats why I used the word 'tend' as some do! But these are thicker older units. Todays models are soldered chips as people want thin units.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 138
