0
Score
axel
153
Asked
What hard disks are compatible with an iMac Intel 24" EMC 2267?
Can I put any 3.5" SATA disk into an iMac Intel 24" EMC 2267, or does this model use the hard disk's builtin temperature monitoring and so need one from the same manufacturer? Will it take a 3TB hard disk? Some sources seem to suggest 2TB is the limit.
2
Score
mayer
121.8k
Answered
Here's an excellent article on upgrading your 2009. It also has links to compatible drives: http://www.everymac.com/systems/apple/im...
The problem with changing drives is the thermal sensor. If you stay with the same "brand" of drive there should be no problem. If you change brands, you will need to change to that companies sensor. As far as I know there are three different ones, the Western Digital 922-9225, the Seagate 922-9224 and the Hitachi 922-9223
I don't know about about a three TB drive.
