Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
Removing screw to replace the screen
Hi,
Im Having trouble removing a screw in my iPhone i have got up to step 8 in the replacement screen guide yet one if the screws will not remove it just keeps twisting. Is anyone able to offer and solutions to the problem?
Thanks in Advance,
Dean
1 Comment
I noticed you never got an answer to this. Are you still having this problem
by
Add a comment
Chosen Solution
Had same problem try this answer. I ended up using a very fine drill bit to remove the screw head. The board then just pulled up and over and I could take screw body out.
screws on motherboard cross threaded-unable to remove
Score 2
2 Comments:
I have the same problem any help would be appreciated
by
consider the answer pollytintop gave
by
Add a comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,413
