Blackscreen after water damage
Hey guys,
My 15” MacBook Pro (Retina Mid-2015) got a bit of water on it while I was not present (apparently it was closed during the mishap).
Not knowing it had received water on it I used it and it worked normally for like 5-10 minutes before having a black screen (for a few minutes the battery did a weird crackling noise as well and the jack port had a red light).
First thing I did is testing it with an external monitor and it works normally: I have access to my OS and my files, keyboard works, speakers work and so does the trackpad.
Second thing I did is flashing a flashlight on the apple logo on the backside (which isn’t working as well), and I did see the screen as if it was working normally.
Therefore I came to the conclusion (after carefully reading a lot of posts on ifixit) that it was most certainly the WLED chip on the logic board, the backlight fuses, or the display itself.
Hence my 2 questions :
- Is it normal that when I called my local Apple certified repairer he told that the main board had to be changed and that it would cost me 1700€ ?
- What would you guys recommend me to do as a next step since I have the feeling that a lot of repairer’s are bullshitting me and just after my money?
PS : Tried PRAM and the SMC reset already and they didn’t work.
Thanks a lot in advance, you’re an awesome community!
