Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
On start up I get 1 second white light on mac then immediate shut off
On start up I get 1 second white light front of the mac mini then immediate shut off.
When i press the power button again it does the same. RAM or HDD still works tested.
2 Comments
Which model do you have? The i5 2.3 GHz or the i7 2.9 GHz which only has the Intel HD Graphics 3000 services. Or the i5 2.5 GHz or i7 2.7 GHz which also has the dedicated Radeon HD 6630M GPU
by
The i5 2.3 GHz Intel HD Graphics 3000
by
Add a comment
1 Answer
Chosen Solution
This doesn’t sound good ;-{
I’m hoping your power supply went on you here’s the IFIXIT guide to replace it Mac mini Mid 2011 Power Supply Replacement and here’s the needed part Mac mini A1347 (Mid 2011) Power Supply - Apple P/N 614-0503 IFIXIT is out of stock so you’ll need to do a bit of searching. Where are you located? So we can aim you to a more local source.
If that fails to fix things then your logic board is toast then its a matter of how much to invest. Keep in mind a new Mac Mini is expected before the end of the year. If you can I would wait to see what Apple offers up. In the mean time you can take your drive(s) out to recover the data to a second Mac system using a SATA to USB adapter like this one Startech 2.5" SATA to USB3 adapter
Score 2
Add a comment
Add your answer
Cemil will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 552
