Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
872 Questions View all
Question Closed
Which hard drive is master and which is slave?
A computer with multiple hard drives has one natively designated as the "main" hard drive. The computer will naturally boot up from this "main" hard drive. I believe this "main" hard drive is called the master.
When tearing down the A1347 Server model, which hard drive is removed first, the master or slave?
Asked another way, which hard drive is closer to the Apple logo, the master or slave?
I would like to replace the master/main hard drive with an SSD hard drive while insuring default boot is correct.
Thanks.
Add a comment
1 Answer
Chosen Solution
Either drive can be master. It's a matter of jumper settings. Some drives will tell you how to set it on the drive, others, just do a web search for the company name and jumper setting. If both drives have systems, it will go to the one selected in the system preferences. If neither drive has been selected as the start up, it will sometimes start and some times not. Hold the option key down on start up to select the system you want.
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,287
