Score
Avatar
bookman32756
13
Asked
Trackpad Connection Problem
History
Occasionally I work on early iBook G4 laptops (800 or 933 MHz). Typically, things go very well until I reinstall the top case. Almost without fail, I have problems reattaching the trackpad connector on the top case to the logic board. Since the connector is recessed under the lip of the top case, I seem to have problems lining it up with the pins on the board. I have literally spent hours trying to get the trackpad reconnected -- very frustrating. Is this just me? Does anyone have advice or a trick that might make this any easier?
Edited by
Post Answer
Score
Avatar
lemerise
15.2k
Answered
PermalinkHistory
I use a small pair of plastic pliers to guide the connector to the socket. The keyboard/trackpad connector is the last connector you clip before closing the top case.
First enter the AC adapter port to the top case hole then align and connet the power switch connector in his socket with a plastic spudger then connect the speakers connector to the speaker socket with the spunger. Once this connector is in place and well connected enter about half to 3/4 inch of the speaker cable in the hole over the speaker socket, if you don't do that you'll have problem to close the top case. Last connector to connect is the keyboard/trackpad connector. Use a small flashlight and light the connector while you're ajusting the top case just over the connector. If you don't have the plastic pliers use the spunger to guide the connector over the socket pins and push it down carefully. If it is not well aligned you will fell a resistance so don't put too much force.
Also (I often made that mistake) before installing the top case on the ibook G4 800 to 1.2Ghz models double-check if the sleep magnet is there under the top case cause the sleep function will not work and you'll have to reopen the case.
0
Score
Avatar
QEII Student IT
3.5k
Answered
PermalinkHistory
Yes, it's very tricky!
Lower the top case until it is virtually leaning on the top shield, then, use a screwdriver or similar to push the connector back so it is directly above the port. Then, push the top case down at the point directly above the connector, making sure the connector is still in position. This may take a few tries but when you get it right the pins will take a very small amount of force to slide into the holes.
Instead of using a metal screwdriver and risking damage, use a plastic spudger or wooden tongue depressor.
David Iwanicki,
Add Your Answer
