HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
17 Questions View all
Removal of the right side of the case of an Officejet Pro 8625?
I cannot for the life of me figure out where to unlock the right (*edited) side panel near where it attaches to the paper feeder. I see the tabs on the underside and the entire thing is separated except in that area where the light grey part I’m trying to pry apart presses against the black plastic for the paper feeder.
I’ve been able to remove the left panel and back panel with no issues, just stuck on this side here. Anyone have any tips?
Thank you ahead of time for any help!
Add a comment
Most Helpful Answer
I know I’m late to the party but, just for anyone who needs to know in future, if you look inside the printer from the front on the paper exit tray you will see two little tabs that you can push down. This will allow the paper exit tray to be removed revealing a small screw that holds the panel in place.
Score 1
Add a comment
It doesn’t come off as illustrated in step 4 here…
HP Officejet Pro 8620 Motherboard Replacement
The text says “pulling down” there but down in the photo would actually be toward the back (normally verticle) side of the printer.
1 Comment:
This is what happens when you spend too many hours messing with a printer--I actually meant RIGHT side. It's currently upside down and my brain is no longer cooperating. Thank you for the answer. That side is a breeze, it's the other that I'm having a disastrous time with.
by
Add a comment
Add your answer
Tammy will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 29
All Time: 769
