HP Officejet Pro 8620 Motherboard Replacement
  1. HP Officejet Pro 8620 Motherboard Replacement, Left Panel: step 1, image 1 of 3 HP Officejet Pro 8620 Motherboard Replacement, Left Panel: step 1, image 2 of 3 HP Officejet Pro 8620 Motherboard Replacement, Left Panel: step 1, image 3 of 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Motherboard Replacement: step 2, image 1 of 2 HP Officejet Pro 8620 Motherboard Replacement: step 2, image 2 of 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Motherboard Replacement: step 3, image 1 of 2 HP Officejet Pro 8620 Motherboard Replacement: step 3, image 2 of 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Motherboard Replacement: step 4, image 1 of 3 HP Officejet Pro 8620 Motherboard Replacement: step 4, image 2 of 3 HP Officejet Pro 8620 Motherboard Replacement: step 4, image 3 of 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Motherboard Replacement, Motherboard: step 5, image 1 of 3 HP Officejet Pro 8620 Motherboard Replacement, Motherboard: step 5, image 2 of 3 HP Officejet Pro 8620 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Disconnect power cable and ground the device and yourself to avoid electric shock to yourself and device.
    • Remove all connectors by gripping the plastic housing the wires and gently pulling outward until they disconnect.
  6. HP Officejet Pro 8620 Motherboard Replacement: step 6, image 1 of 2 HP Officejet Pro 8620 Motherboard Replacement: step 6, image 2 of 2
    • Gently disconnect connectors by gently pulling on the plastic housing until they release from the motherboard.
    • Gently grasp the ribbon connectors so they do not bend by gripping top and bottom and lightly pulling until they release from the motherboard.
  7. HP Officejet Pro 8620 Motherboard Replacement: step 7, image 1 of 3 HP Officejet Pro 8620 Motherboard Replacement: step 7, image 2 of 3 HP Officejet Pro 8620 Motherboard Replacement: step 7, image 3 of 3
    • Remove the four 8mm screws by using a T9-Torx screwdriver, turning counter-clockwise until released.
    • Lift the ribbon connector in the center of the motherboard away after it has been disconnected to access the last screw.
    • Move the plastic piece away from the motherboard before removing it.
  8. HP Officejet Pro 8620 Motherboard Replacement: step 8, image 1 of 2 HP Officejet Pro 8620 Motherboard Replacement: step 8, image 2 of 2
    • Release any remaining connectors from the motherboard by gently pulling away until they break free.
    • Remove the motherboard.
    • Mark each connector or remember their placement for reinstallation to avoid damage to components. If the connector does not snap in easily, don't force it.
5 other people completed this guide.
Jeremy Taylor
442 Reputation
2 Guides authored
Cal Poly, Team S19-G2, Livingston Winter 2018 Member of Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Members
8 Guides authored
One Comment
Dear Sir,
could you send me the electronic schematics for the HP 8610 motherboard and side panel . I have a problem with the switching on of the unit
thank you
Stephen Proverbs
s_proverbs@caribsurf.com
s_proverbs - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 3,958
