Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 Questions View all
Brake lights fail to get brighter when brakes are pressed.
I have a 95 Chevy K2500. All 7 of my rear lightbulbs work properly, blinkers and all. But when I press my brakes, only my cab lights up. I checked the fuses so if anyone knows any specific spots to check for wiring issues would be great.
Add a comment
Chosen Solution
kentchris85
the cab brake light (center high mount stop light) is on a totally different wiring harness. So, the only thing you know is that this is not your brake light switch. You want to go ahead and check the wiring harness located by the license lamp breakout under your box running along the inside of the frame, measure on there for continuity and check for broken wires and corrosion.
You also need to check inside the "underhood relay box". There should be a relay for the brakelight circuit. You can verify if it is a good relay by swapping it with one of the other 4 pin relays. You could also temporarily place a jumper between terminal 30 and 87 and see if your brake lights come on. If so, you know that the wiring is okay but you are having a relay issue. If not place a test light in terminal 86 and 85 and press the brake pedal. If the atest light comes on then you have power goin to the relay.
The rear brake lights are wired through the multifunction switch. So a bad switch (that is the turn signal switch on your column) can be at fault as well. At the rear the brake lights and turn signals use the same bulb filament, just not at the same time. Check voltage and ground at the rear.
Score 3
Add a comment
If the middle light is lighting then you know the brake switch is good. Most likely someone put in the wrong bulbs in to the brake light sockets. The brake light socket has two contacts at the base of the bulb unlike the tail light.
Once you pull the bulb you can use a DVM to test the contacts where someone presses the brake peddle you should see voltage on both pins to ground with the lights on and when the tail lights are off one pin should still have power (the brake side) in case the line is cut.
Score 2
Add a comment
Add your answer
kentchris85 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 5,058
