Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
495 Questions View all
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
Score 1
1 Comment
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
by
Add a comment
Chosen Solution
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
Score 2
6 Comments:
Simple, brilliant answer.
by
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
by
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
by
Show 1 more comment
Add a comment
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
1 Comment:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
by
Add a comment
Add your answer
Den Gauthier will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 53
All Time: 1,750
