Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1204 Questions View all
Question Closed
Display turns dark, Icons remain dimly visible
Regards, ... I have the Macbook A1181 for two years.
It turns on normally, but within 5 seconds goes to black screen. (the other functions are operational ) If I light up the screen with a lantern, I can distinguish the icons on the screen. Fans function-- normal temperature, no noise but only allows me to recover some of the image when I reduce the brightness and gradually increase to 2 or 3 points light. When I get up to 5 or 6 the screen turns black again.
I've worked with Logic until last week but occasionally had to pause due to temperature increase---could this be one cause ?
When I try to play a movie does not even allow two points of view it with brilliance.
Any suggestions?.
Thanks for this site and greetings to all, see you soon.
Nacho.
2 Comments
Please start a new question. Cut and paste what you have here but also please explain your problem in your native language, someone here can translate it.
by
sth wrong with the power-supply of back-lights, i guess.
by
Add a comment
Most Helpful Answer
Hook it up to an external monitor. If that works I would replace the inverter. Here's how I do it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
If the problem comes and goes as the display is moved, then go for the inverter cable.
Here's the part: MacBook Display Inverter
MacBook Display Inverter Image
Product
$14.99
Score 2
1 Comment:
I have replaced the inverter and the cable but still no luck. If I 'jiggle' the connections to the inverter the screen lights up momentarily then goes black again. Any ideas? I'm about to replace the backlight as the last option!
by
Add a comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,672
