0
Score
nacho
23
Asked
Display turns dark, Icons remain dimly visible
Regards, ... I have the Macbook A1181 for two years.
It turns on normally, but within 5 seconds goes to black screen. (the other functions are operational ) If I light up the screen with a lantern, I can distinguish the icons on the screen. Fans function-- normal temperature, no noise but only allows me to recover some of the image when I reduce the brightness and gradually increase to 2 or 3 points light. When I get up to 5 or 6 the screen turns black again.
I've worked with Logic until last week but occasionally had to pause due to temperature increase---could this be one cause ?
When I try to play a movie does not even allow two points of view it with brilliance.
Any suggestions?.
Thanks for this site and greetings to all, see you soon.
Nacho.
2
Score
mayer
121.8k
Answered
Hook it up to an external monitor. If that works I would replace the inverter. Here's how I do it: Repairing MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181
If the problem comes and goes as the display is moved, then go for the inverter cable.
Here's the part: MacBook Display Inverter
Please start a new question. Cut and paste what you have here but also please explain your problem in your native language, someone here can translate it.
mayer,
sth wrong with the power-supply of back-lights, i guess.
Sosoon,
