Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 Questions View all
98 gmc 4.3l v6 oil pan removal
i have all the bolts that i can see from the bottom of the pan, but the pans still hung up i figured it would drop sorta easy with all the bolts out but there must be some i missed. where do i go from here? take the trans out, the whole motor out?
Score -1
Add a comment
1 Answer
Chosen Solution
Tap it gently with a small rubber hammer all around the seam. There may be a gasket that's holding it in place. Use a flathead screwdriver on the end to break the seal loose. You can also use the back of your fist and bump it loose.
Score 1
1 Comment:
Careful wit the screwdriver that you do not bend the surface for the gasket, or you will have a leaky pan.
by
Add a comment
Add your answer
steven boomer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,624
