Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 Questions View all
2011 iMac potential GPU failure, worth replacing?
Hi,
I bought a mid 2011 27-inch imac last year for about £400, did it up replaced the ram changed the drives out - was perfectly good for everything I needed it to do, until recently when it suffered what I assume was a GPU failure (very characteristic of this model)
the screen would occasionally flash and distort, sometimes I'd get lines on the screen, and then it crashed, and now it won't boot (the loading bar gets about halfway up, freezes, and then i get the grey screen of death).
I'm just wondering whether people think it's worth salvaging. Obviously the boat has long sailed on the apple replacement program for GPUs on this model, and I bought it secondhand anyway so have no "applecare" or insurance. I've noticed people sell the replacement cards online, but they're about £200 (from what i've found at the moment) from china, and while I don't mind fiddling around in one of these machines, getting to the motherboard is not an easy process.
Considering all this, especially that it's £200 for a 7-year old part, I don't know if I'm better off spending the £200-250 and hopefully bringing back a great iMac to full working order, or if I should strip out my drives and let it go to the apple graveyard and invest the £200 elsewhere.
While it seems like a shame to just bin it off, especially after such a hefty investment in it, I'm slightly worried about fixing it only for another issue to present itself a few months down the line, and my £200 fix to have been another waste of money. Especially considering it's an old and outdated machine.
Score 3
Add a comment
Most Helpful Answer
I have had a 75% success rate doing a reflow of the GPU using a hot air work station. The replacement GPUs are expensive due to supply and demand. So if you go that route be sure to get as long a warranty as you can. If buying off eBay, get an extended Square Trade warranty.
This is the guide for the 2010 but should work for you:
iMac Intel 27" (Late 2009 or Mid 2010) Graphics Card Replacement
27" iMac (Mid 2011) AMD Radeon HD 6770M 512MB Video Card
Replacement, 27" iMac (Mid 2011) AMD Radeon HD 6970M 2GB Video Card
661-5969
27" iMac (Mid 2011) AMD Radeon HD 6970M 1GB Video Card
661-5968
661-5967
661-5967-R
Score 2
Add a comment
Its a standard laptop part called MXM. The GPU you can upgrade to a newer mobile GPU like the GTX 980m for less then replacing it with another HD 6950m that will fail again in the same way
Score 1
Add a comment
Take it out and put a pencil torch to the chipset , keep it moving around for about a min. Let cool and replace . I have the same model and have done this 3 times already . Works perfect.
Add a comment
Add your answer
adam thompson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 13,096
