Burnt relay what caused this
What caused this burn
This looks like a run capacitor to me. How about telling us the make and model number of your appliance.
An electrical issue usually is what causes the run capacitor to malfunction. When the PTC doesn't correctly indicate the refrigerator's temperature, the run capacitor won't know when to turn on. It could turn on too frequently or not at all. When the capacitor is not working properly, usually you'll hear a clicking sound either before or after the compressor turns on. When you're checking whether the run capacitor is working properly, you can use a power meter to gauge how much energy is being passed between the PTC and the run capacitor. Your owner's manual should tell you the amount of energy that should be passed if it is functioning properly.
UPDATE
Here’s your part:
WPW10662129 - Whirlpool Refrigerator Capacitor
Capacitors fail, it’s just a fact of life. The capacitor can fail because the motor is getting old and takes more to start, surge/voltage spike (either from the line or bad motor's back-emf), or just it failed/life expectancy was reached. ... Capacitors (similar to light bulbs) will fail at some point.
It’s a whirlpool gold not sure where to find the I formation is this it GR2SHK/GR2SHM? I actually bought this from someone so I don’t have the manual. So did my plug outlet burn it? Not understanding? Thank you
Ok so what about the piece that has the burnt hole in it? Do I have to replace that as well? Can I also make a note that the guy told me my plug wrecked the fridge is this false? I actually don’t want to deal with it anymore but just need to know...thanks a bunch...and for the link you gave me it says it’s out of stock...
Pat, I'm not your mother, I'm just a volunteer here. You know the part number so Google it. As to your plug, I have no idea about that. So, I don't want to deal with it anymore.
Ok thank you ☺️
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 54
All Time: 5,239
