Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Questions View all
Sensor error Tp2H, heatpipe, power supply
Hey all,
I've got an iMac late 2012 and to date it worked without any problems.
But after having updated to High Sierra, more and more problems appeared.
The system became slower and unresponsive. Today it reached the climax.
The screen turned black several times in a row, as if it would hibernate.
I started the Apple Hardware Test and it gave me this:
4SNS/1 /40000000 Tp2H-127.875
This means, that the powery supply / heatpipe reached a level of 127°C.
But I'm pretty sure that the sensor is just broken. I bet the system would blow up, if the temperature was real.
Now the question is, can this be easily fixed or does that mean the whole LogicBoard needs to be replaced? And is this worth it ($$$)?
Cheers,
Stephan
Score 1
Add a comment
1 Answer
Chosen Solution
@stevie_
Sensor
Tp2h
Description
AC/DC T2 Sec heatsink temp
Part Location
Built into power supply
Suggested Action
Check power supply cable connections to logic board; test with known-good logic board; test with known-good power supply. Check for clogged fans and/or vents; check cable connections to logic board.
Score 1
3 Comments:
Well that sounds (worst case) like either the Logicboard or the Power Supply needs to be replaced.
Does anyone know what such a repair will cost?
by
Here's the IFIXIT power supply: iMac Intel 21.5" (Late 2012-2019) Power Supply as the sensor is on the power supply you have a good chance thats the likely part that will need to be replaced.
by
Very cool, thanks! Didn't know that the sensor is located on the PSU itself.
by
Add a comment
Add your answer
Stephan Römer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 808
