Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Home button sticking after I replaced digitizer
The home key is sticking after I replaced the digitizer on my iphone 3g. It appears to be properly aligned, however, I am no expert at phone repair, so it may not be. The home key is fully functioning, though. What could be causing this, and how can I fix it?
Score -1
1 Comment
Home button sticking is to vague. What do you mean? Pressing it is not smooth, or a simple push results in multiple clicks. If pressing is not smooth then possibly you placed the digitizer adhesive too close and it is touching the home button. If so clean home button with isopropyll alcohol a bit generous so it can seep down at edge of Home Button and dissolve the missaligned adhesive. Tell me your Home Buttom problem in more detail so we can help you fix it. Brad
by
Add a comment
1 Answer
Chosen Solution
Open the phone back up, flip the display over and have a look at the gold prongs. They should be raised slightly up from the home button assembly. They are very fragile but if they're a bit flat this may be why it feels like it's sticking
Score 1
Add a comment
Add your answer
Mallory Harber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,017
