1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Questions View all
Any way to read part of screen that’s broken during Apple HardwareTest
So I’m working on this reclamation project for this 13” 2010 MacBook Air. About 1/4th of the screen is broken, so normally I have it hooked up to an external monitor, which works fine.
Problem started when I replaced the keyboard recently after it’s power key stopped working. I did the replacement fine, the keyboard now works, but the computer is ghastly laggish when it’s doing anything.
I burned Apple hardware test onto a bootable USB, and ran the diagnostic, but the error code that it spits out is half-blocked from the screen damage. Bc it’s in AHT, the external monitor doesn’t work, and I can’t move the window to where I can see the whole code. All I can make out is “4SNS/1/40...” and that’s all I can see.
Is there anyway to figure out what the rest of that code is? I can’t seem to select text so copy and paste doesn’t seem to be an option either.
Add a comment
Most Helpful Answer
Print the screen or capture the screen and then print it.
Score 2
Add a comment
I may be wrong @mayer correct me on this , but if you start the macbook up in clam shell mode you can see the diagnostics on the external display.
https://support.apple.com/en-gb/ht201834
Score 1
Add a comment
Add your answer
vinet09 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 43
