0
Score
Avatar
Gary Lam
Asked
Screen backlight is not working...ok when plugged into a monitor.
History
Macbook Pro 1.83 Intel Core Duo
Hello, my problem all started with my screen flickering with the moving of the screen up and down, I changed the display data cable, the inverter and the isight cable...the problem remained. At one point, I thought it might be the isight/inverter cable that comes out of the left hand side of the hinge...so I purchased another one and replaced that one as well. and since I've changed those three cables, actually now there's no more flicker...the screen just has the faint image...should I try changing the other side of the inverter cable as well? Or am I dead in the water and just need a new LCD? I plugged my mb pro into a monitor and the images are just fine...so i think I might need another lcd screen...any help would be appreciated.
Edited by
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
If you're still getting a faint image, your inverter or inverter cables has failed. Here's the part you need, the installation guide is located of the parts page: MacBook Pro 15" (Models A1150/A1211) Display Inverter
Edited by
Product Image
A bad inverter board can cause a dead backlight — 2 available at 69.95 each.
thank you so much for the response...do you have the link for the inverter cables?
Gary Lam,
Add Your Answer
