Low water flow to machine
When first started flow seems OK, then slows down.
When you stop the cycle and then restart, flow picks up only to have it slow down to a trickle
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Did you make sure the water valve is fully open if so maybe if you aren't using your dishwasher during use of your laundry washer would help try to have low water consumption during the use of your washer. Is the hose into the washer kinked? Is it on the right settings? Let me know if this helps, Good Luck!
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 285
1 Comment
Please do not ask the same question three times in a row.
by mayer
