Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
My iMac Late 2009 Display, flickering, dimming, and pixelated
Display has been flickering and dimming during startup for a while now, didn't really bother me, until I upgraded the hard drive to an SSD. Then the display started to become pixelated. I have already connected the iMac to an external monitor and the problem does not transfer to the external monitor. Attached is a picture how it currently looks. Not sure if the picture shows the extent of how pixelated and oversaturated the colors look. Any help will be greatly appreciated thanks.
Score 1
Add a comment
Most Helpful Answer
Hook it up to an external monitor to help isolate the problem. If the issue persists you will need to replace or reflow the GPU.
Score 2
1 Comment:
I've hooked it up to an external monitor and the external monitor looks fine, which leads me to believe that the display or connectors are faulty.
by
Add a comment
Hello Alex,
I can almost guarantee it is not the SSD that is causing the issue. That should speed up the laptop if anything. Although, I did some research and found an answer to this question previously. Because I don’t intend or care to take credit for their knowledge, here is the post that was solved with a person having the same issue: Scramble/Pixelated then flickering screen..
Best of luck!
Score 1
1 Comment:
Thanks for the reply but I don’t believe that’s the solution. I did minor reaseach on the Nividia settlement and it looks like laptops were the only ones affected. This problem is happening to a late 2009 iMac I’ll take a better picture of the problem because I just checked through my iPhone that the picture I posted through the iMac shows the screen normal.
by
Add a comment
I have an late 2009 iMAC 27inch. Have similar issue with screen. I post it the image. Does anyone see this problem before? I ran hardware test showing 4hdd/11/40000000:sata(0,0). I am not sure if this hard drive code correlate with a screen problem. Any thoughts on this?
Add a comment
I also want to add that when I run the iMAC in safe mode, the screen looks fine.
Add a comment
Add your answer
Alex Suarez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 728
