The Kenmore 90 Series is a washing machine manufactured by Kenmore.
267 Questions View all
Agitates while filling and rinses while spinning
My 6 yr old Kenmore washer has started agitating while filling and pouring water while spinning. I've had to leave the lid open initially and then turn the water off during the spin cycle. Thank you for your help.
Score 1
Add a comment
1 Answer
Most Helpful Answer
The problem could be a faulty timer or pressure switch. I recommend unplugging the washer and opening the console. I have provided you with the instructions for accessing the console below. Then locate the pressure switch. It is the part that has the small hose connected to it. Once you find the pressure switch, unplug the wires to in. then plug the washer back in and start a wash cycle. If the washer does not do anything, the pressure switch needs to be replaced. If the motor still runs or makes noise the timer needs to be replaced.
Score 1
2 Comments:
Please clarify "unplug the wires to in" I don't understand. thanks
by
@Ed Castle
I think it is a typo and it should say "...find the pressure switch, unplug the wires to it."
What is the model number of your washer?
by
Add a comment
Add your answer
Marc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,748
