How factory reset with Disk
I'm not too fan of This devices i'm a little lost i wanna delete everything i have the disk just don't how to reset it command + R doesn't work
Just a quick note: Command + R only works with OS X 10.7, 10.8, and 10.9. Versions of OS X prior to 10.7 will require the use of a start up install disk.
If you have 2009 model then you should have a Recovery partition in it if it was installed correctly. If you have tried holding down the Command and R keys while restarting and it does not go to the recovery partition, then something is wrong.
Try restarting by holding down the Option key. If there is a Recovery partition, it will show up then.
Model is A1224 i believe is from 2007- 2009
it give me option thank you
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 10
All Time: 162
