Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
Screen not responding after replacement.
I am almost done replacing a broken screen and am attaching the connectors to the logic board. I have worked with these type of connectors before, but after getting them all connected, when I plug the phone in and turn it on all that happens it it beeps to let me know that it is now charging, but the screen is dead. Everything was working before I replaced the cracked screen, so what could be the problem? I have checked the connectors twice and still nothing.
Thanks for any help,
John-Paul
1 Comment
check you have the right screen.. not a 3gs
by
Add a comment
Chosen Solution
Make sure the connectors are on, and then flip the silent switch on/off about twice and hold down both the home and the power button. Have the phone plugged in while doing all this. This is a hard reset and usually helps.
Worse case if it doesnt work, remove the board from the housing for about 5 minutes. attach everything and plug it in. This helps when I get a stubborn phone.
Score 4
5 Comments:
Thanks,
This fixed my problem!
Have a great day!
by
Thank you, this fixed my (similar) problem as well!
by
Great! Please vote (left arrows) up the answer when it helps! Thanks!
by
its working its working, i love u man, from a happy irish man
by
:) please vote up if it worked for you
by
Add a comment
Did not work with either options
Add a comment
Thanks it worked great
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 4,301
