panic kernal on 5 out of 6 hard drives. Can they be fixed?
Can these hard drives be repaired ?
2 layers of text when using an install disc.
bottom layer says shut down & restart.
top layer has endless scrambled text with isolated words, i.e. panic & code interspersed within the text
Add a comment
1 Answer
Most Helpful Answer
That many hard drives failing with a kernel panic indicates to me that your problem lies elsewhere.
When you boot from the install disk with no hard drive in what happens?
Is this a retail system installation disk? What system is it? Is it a machine specific "grey" installation disk and what system is on it and what machine does it say that it's for?
UPDATE
Pre-Installed MacOS: X 10.3.7 Maximum MacOS: X 10.5.8
There are other ways to format than Disk Utilities.
Here's How to Erase a Disk from Command Line in Mac OS X:
http://osxdaily.com/2016/08/30/erase-dis...
Here's how to use Terminal:
http://smallbusiness.chron.com/format-os...
Score 1
1 Comment:
One hard drive did boot up properly with the retail disc that I used.
I have accumulated gray discs & retail discs with the leopard (not snow leopard) with similar results.
By the way, Mayer, you have the best track record on this site.
Thank you for your time.
by
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 51
