0
Score
Avatar
Travis Mo
Asked
Why is my screen white after I replaced the lcd and digitizer?
History
Recently i crakced my screen and ordered for a replacement. Upon recieving my new lcd and digitizer i installed it carefully and assembled it back to original. my problem is that when i tryed to turn it on the screen is white. i tried to do a reset by holding the home button and screen lock button for 30 to 40 seconds but it is no working. any ideas of what i may have done wrong or could it be a faulty part? thanks so much -travis
Edited by: pollytintop ( )
I just tried to fix an ipod touch 4g with cracked glass. After a careful teardown and re-assemble I encoutered the same issue. I even tried connecting the old screen with the cracked glass but found the same white screen haunting me. I am going to try recboot but I am now wondering what to recommend to the customer I have. Any progress Travis?
Bill Artz,
Hey bill. I did eventually get mine to work but I ended up getting another new lcd from the same guy who sold me the first one. When I plugged in the second one it immediately showed up. If your having the same issue then out could possibly be a faulty lcd. I was also told the lcd and digitizer had to be fuzed together but they were incorrect cause mine works just fine in two separate pieces. I hope this helps! -travis
Travis Mo,
Post Answer
2
Score
Avatar
oldturkey03
88.1k
Answered
Accepted Answer
PermalinkHistory
Travis Mo, it is always possible that it is a defective product, but first what I would do is to disassemble again and triple check the connections and to make sure that everything is seated properly and that all cable and connections are clean and straight.
it looks like everything is clean but its hard to tell if im lining up the part where the ribbon cables connect to the motherboard. i assume its got a good connection cause it clicks it and seems like its how it should be but still no luck...
Travis Mo,
thanks guys for you help. i havent had a chance to try it again cause ive been busy but hopefully today ill get a chance and let you know if it worked.
Travis Mo,
Score
Avatar
Adam Boyd
37
Answered
PermalinkHistory
this is a common problem, look for a program called recboot stick the ipod into recovery mode and wait a min, then connect to itunes, then quit itunes again, run recboot again and kick it out of recovery mode this should sort it out, if not then it is possibly a fault caused by static which can sometimes resolve by running the battery completely flat and leaving alone for a day or so then put a little charge in it again!
so i tried using recboot and it told me to download usblibO.dll and some other file so i did but after following a tutorial on how to do it i still couldnt get my screen to show anything but black or white. i can tell its connected to itunes cause my computer notifies me that its connected but i still cant figure it out. thanks for the help
Travis Mo,
Score
Avatar
Tristan
422
Answered
PermalinkHistory
Although i have a 3GS, i had a similar problem after replacing the glass. However i had fixed my screen by pushing down on the connector, it apparently wasn't in all the way so it just showed the white screen. Try it out and tell me how that goes.
Score
Avatar
c66l6
13
Answered
PermalinkHistory
it is the connection I hold mine down and it works and I le it go I feel it move and it goes white. the LCd connector is a pain in the rear end to stay down while putting the screen in place
Update
it is the connector when I hold it down it works but when I let go it moves and the screen fades to white. so the connection is incomplete. Th connector is a pain to keep down in the replacement.
Edited by: c66l6 ( )
Score
Avatar
Carsten Madsen
13
Answered
PermalinkHistory
I have just managed to replace digitizer/lcd. First the result was white screen. Then I changed back to the old screen but now that was white too. Then I tried to reset ipod like described holding home, vol. Up and then power button. Hold all three buttons until the screen turns on and show the apple. After several tries it worked and I replaced the old screen with the new again and it worked. Good luck.
Sorry bro i just copy and pase your answer,but your way works perfectly...deam cool,Thx man... # I have just managed to replace digitizer/lcd. First the result was white screen. Then I changed back to the old screen but now that was white too. Then I tried to reset ipod like described holding home, vol. Up and then power button. Hold all three buttons until the screen turns on and show the apple. After several tries it worked and I replaced the old screen with the new again and it worked.###
Vaidase,
Score
Avatar
john
25
Answered
PermalinkHistory
In most cases its a loose connection or you need to reset the device.
On the other hand I've actually seen screens go white that are defective. To double check, I hang on to a couple of old cracked screens just to connect up to rule out a bad replacement part.
Be careful though, pulling up that logic board over and over to re-connect the (thin cable) to the bottom of the board can be trouble - logic boards have a tendency to snag the power/volume flex cable and tear it, which means soldering and a lot of hassle. I smooth down the power cable with a pry tool and stick on a piece of Kapton tape (after a few "costly" mishaps) before pulling up the logic board.
Last, don't use your finger to snap down the cable onto the board -- use a pry tool - gently, because too much force can break off the connector on the logic board and your into big mess.
Score
Avatar
michael
13
Answered
PermalinkHistory
Hi, mi name is michael monreal, im a apple techinician, okay to solve this problem, conect everything on the ipod, make sure everyting is on the right place. after this, if you have the WHITE SCREEN. press down Power+home botton. this will cause the motherboard to refresh, because the static caused to {crash}
i hope this solve your problem any questions Michael0master@hotmail.com
Score
Avatar
Willem
13
Answered
PermalinkHistory
Hey
I got the same problem.
http://desmond.imageshack.us/Himg513/sca...
But if i put the old screen in, all works fine. But with the new I got this. I already reset the ipod etc but nothing seems to help.
What do I need to do?
Kind regards
0
Score
Avatar
Ian Dixon
Answered
PermalinkHistory
i have the same problem... white and black... SOOOOOOOOOOO mad, but, i think my problem is that when i tried to put the fatter ribbon coming from the digityser, the ribbon was not clicking in, and i might not have realized it, but can someone PLZ tell me what that wire is for... becouse i think it is for the color on the screen, but im still not sure. plz tell me.- Ian.
0
Score
Avatar
Lymus
Answered
PermalinkHistory
Hi,
I have similar prob. Few weeks ago I have replaced LCD assembly to one customer, and it worked fine. After 5 days he brought it back to me because it was showing just a white screen. I have opened and checked LCD connection tried it again, and for a few seconds it came back to live, but then again back to white screen. I fitted another brand new LCD unit and it worked just fine, but today, after 4 days, i have received a call from him saying that again he is got just white screen. Did anyone had similar issue with these LCD units, and maybe someone can give me some advice. Thanks.
Hi everyone, Just have sorted problem. The solution was one more brand new screen. So it took me three screens to sort this out... Anyway I do think, that you must be extra careful when replacing these screens, as these flex cables are very fragile, and it is very easy to damage them.
Lymus,
0
Score
Avatar
kamil
Answered
PermalinkHistory
i have rcived 2 new screen for Ipod 4g first one is working fine after asspled by reset onle the prablome bing solved.but the scond one i have semelare what you have ....!!!!!! any one can advce
thanks
0
Score
Avatar
ieman
Answered
PermalinkHistory
i just fixed my lcd screen and when i pluged it in to charge the screen is staying black but its making the sound it makes when its plugged in i dont know what to do any answers ? :(
0
Score
Avatar
conner
Answered
PermalinkHistory
if it is a white screen then let your ipod die and then plug it in let it charge and it should work just fine.
0
Score
Avatar
Krayzee
107
Answered
PermalinkHistory
sometimes for a white screen i find disconnecting the battery and connecting it again is a fix, not for the faint hearted or inexperienced
0
Score
Avatar
Simon Pan
Answered
PermalinkHistory
Recently, I bought iPod Touch 4 LCD Assembly from China after replacing it, my screen went to white only. Eventually, I realized that Digitizer connector is different from original one. The original one has wider plastic block in the middle of connector than faulty one from China. Do you think that the different connector makes white screen problem?
0
Score
Avatar
Country Computer Service
2.1k
Answered
PermalinkHistory
I've ordered from wholesaler's that get their products from China. A few months back I got a batch of replacement screens and none would work. The replacements, which I received, had 4 rows of connectors on the thin cable vs 2 rows that is standard on the stock screen that came on the iPod.
If you look at the one in the top photo, the one with 4 columns of pins, I could never get those to work.
However, the bottom photo, is a replacement that matches the connector that comes built in from the factory. They have all worked fine.
Score
Avatar
Micah Roemmich
Answered
PermalinkHistory
The white screen problem is easily fixable, since it's a static crash when you deal with the LCD, it's just power button + home button for 7-10 seconds. My problem is getting the Digitizer to work once the LCD is working fine. Having issues with the digitizer connecter at this point, I'll post an update as to what it is later..
0
Score
Avatar
blane
Answered
PermalinkHistory
The rest woked. I was about to sell my 4th gen 32gb as broken until I read this thread. Thank-you you saved me a pile of money.
0
Score
Avatar
juan
Answered
PermalinkHistory
While holding the home button down and volume up button, push and hold the power off button and hold that until you see the apple sign.
Update
try it will really work !!!!!!!!!!!
Edited by: juan ( )
0
Score
Avatar
russell
Answered
PermalinkHistory
ok so i have a problem too i replaced the screen all was fine and working untill i realised i forgotten the sticky double sided stuff so i open it up and connector came off so i pushed it back in and now all i get is the white screen i connect to itunes done a restore and still no joy tried resetting with vol up power and home but still no joy ??
0
Score
Avatar
Luis Sandoval
Answered
PermalinkHistory
I have had the same problem. It happens that I had replaced the screen and It worked fine but It was one of the older iPod touch 4g when it can out. My sister also had a cracked screen so I had offered to fix it for her. I followed the same procedure and everything came out well after a few connection problems wight the touch sense cable below the logic board. I left it clamped overnight for the adhesive to get the screen in the right place. In the morning I plugged in the iPod and clamped it a little more with heat and the screen turned white. I tried to open it again and place the digitizer cable correctly and the screen stays white after a few resets with the home and power button. Please anyone if you can help do because it is my sisters. Thanks!
0
Score
Avatar
chris estrada
Answered
PermalinkHistory
I have had the same problem. I ordered a new screen and its still white. I also pressed the home button and the power button at the same time and its still white. Can somebody help.
0
Score
Avatar
Samantha Manington
Answered
PermalinkHistory
I love you guys I have spent most of my weekend trying to sort my old 3GS out and now it turns on!! Still having problems with the bottom row of the keyboard working if anyone has any ideas on how to fix this????
0
Score
Avatar
damien
Answered
PermalinkHistory
i tried all ur guys ideas nothin worked ive just found this site give it a try it just worked for me ..... http://www.ehow.com/info_12148465_happen...
0
Score
Avatar
Pedro Afonso
Answered
PermalinkHistory
I have the save white screen, but Recboot solve the problem. Thanks!
0
Score
Avatar
Stephan Schu
Answered
PermalinkHistory
I had the same problem. I replaced the screen and after I put everything back together I got a white screen. Hard reset did not help.
The connectors on my replacement screen didn't have the black rubber protectors on them that all the other connectors in the phone have. So I just put a few layers (2-4 layers should do the trick) of electric tape on the screen connectors so the shield that goes on top of them would push them down. I turned on the phone and was greeted by a lovely apple logo right away.
Hope this helps.
Add Your Answer
