Repair guides and support for Digital SLR cameras by Nikon from the high-end professional range to the entry level consumer cameras.
629 Questions View all
Used Nikon D4s with new sensor
I'm looking at buying a used Nikon D4s that the sensor was replaced.
I haven't considered this in my research but I am wondering if this is a good idea or not. The body will come with a warranty and is priced appropriately for what it will come with.
Any advice would be much appreciated.
1 Comment
The camera's specs: Nikon D4S DSLR
by
Add a comment
Most Helpful Answer
A replaced CCD shouldn't an issue if it was done properly. If you have access to the camera (with lens) take a grey card with you and take a good set of images of it at different EV levels so you can see the range of the noise at both high and low ISO settings (sensitivity).
You'll also want some graph paper to also shoot to see if you see any aberrations in the parallel lines and the focus is even (make sure the paper is mounted and you hold the camera squarely).
If these all look good you shouldn't have any issues.
Score 1
Add a comment
Live screen are not focusing the subject
1 Comment:
@abhishekthakare - Can you please expand your thought here. If your camera is having an issue please post a fresh question as this is an old post and was testing if a used system which was serviced is a good purchase.
by
Add a comment
Add your answer
David Bigalk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 92
