Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
iMac 24" A1225 2008 BLACK SCREEN after graphic Card replacement
Had to replace the graphic card because of stripes. After that the imac starts properly but without backlight. Everything works fine with an external display. 4 LEDs are on. Ive checked all connections already and replaced the the inverter power cable... without success.
So, after reading the forum here, the most probably 3 faulty parts are:
1. The inverter
2. The CCFL Tubes
3. Faulty Parts on the power supply
Can somebody give me an advice how i can check each parts and sort it out? What are your experiences in those cases which part is more likely?
Thank you! ;-)
Update (02/10/2018)
So... i got the donor LCD-Panel today... unfortunately the Display remains dark. :-/
So, i will check the power supply at next...
Update (02/10/2018)
After a little research... i think, THIS seems to be the more promising workaround:
https://forums.macrumors.com/threads/ima...
Add a comment
1 Answer
Chosen Solution
If you can discern the desktop when it is on, replace the inverter, (it was a weak point on the 2007 model).
Score 3
4 Comments:
Ok, then i will concentrate on the inverter first.
by
Did inverter fix your problem?
Mine goes dark after 1 sec after turning it on. I bought inventer on ebay used, but it didn’t help
by
@sunnylelik can you discern the desktop by holding a flashlight ay an angle to the screen?
by
@mayer yes, here is my post about it
Screen goes black after 1 sec
by
Add a comment
Add your answer
Robert will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,146
