Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
iMac 2007 Power Supply Not Showing Output
I bought an old iMac for $50 a week ago and have been trying to figure out since what's wrong with it. None of the diagnostic LEDs light up when the power is connected to the computer. I have tried two separate power supplies, both of which show the same issue: no pin, when measured relative to ground, shows any output voltage. I followed the voltage chart here, but no pin shows anything on either power supply.
+120 VAC is present across the leads coming from the wall, so the board is receiving power. I tested the fuse on both, and on one the resistance indicated it was blown, so I short circuited it.
The large 150 uF, 420V capacitor on each board had positive leads that looked heavily corroded, so I soldered a new one onto one of the boards, in case that was the issue.
Alas, the issue still remains. Any ideas?
Add a comment
1 Answer
Chosen Solution
@cloonam it seems like you are dealing with two separate power supplies with a bit of history to it. From what you are describing it does sound like both of those have failed. Without a schematic of the power supply it will be difficult to repair them. Give us the numbers on the board of the PSU should be Delta power supply. I'd try and start with a known-good power supply for your iMac.
Score 2
2 Comments:
The numbers are 1W07449GUZEHA and 1W073817HZEHA. I was hoping that it could be solved without getting yet another power supply, but I’m starting to think I’m going to have to.
by
more like a Delta ADP-170 and they must have been sworn to secrecy by Apple. Schematics are almost non-existent.
by
Add a comment
Add your answer
Chris Loonam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 400
