The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Questions View all
How to remove the gray silicon rubber adhesive
I got in the capacitor kits, opened up a couple of different iMac G5 power supplies only to find them packed with gray silicon rubber adhesive. No wonder these things overheated. The question is: is there some easier way of getting this crude out other than cutting, picking and pulling?
Score 2
Add a comment
Chosen Solution
The only stuff that I know of is Acetone. Of course not sure how the electronic components and the PCB will hold out to that. 3M makes a product that the boaters down here use. It's a citrus based adhesive remover and they say it takes of the silicon adhesive used in boating. It's a sticky situation with the components but worth a try. Good Luck.
Score 2
2 Comments:
+ It's called ":goo gone", I'll give it a try and let you know
by
Thank you for accepting my answer and I hope you get the goo gone quickly.
by
Add a comment
You could pick a small piece off and test alcohol and other safe solvents on it. You would be looking for a reaction that would allow you to peel the stuff off. Of course ideally it would dissolve. Good luck with it and plus for the question--never an easy answer.
Score 2
1 Comment:
+ for that. Isn't it cruel to waste the alcohol.
by
Add a comment
Add your answer
mayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 767
