Repair manuals and support for 4-wheeled passenger and cargo vehicles.
11873 Questions View all
Where is the thermostat on a 1997 Nissan truck 2.4L engine
My mechanic recently informed me that I needed to replace my thermostat. We briefly met under the hood of my truck and he assured me that the repair was similar to other thermostat replacements I had done (once) some twenty years past. I asked that he confirm the location of the T-stat, and he pointed out the most logical area at the engine block side of the upper radiator hose. Now empowered with knowledge and some self confidence, I tore into my truck only to find no T-stat at that location. After serveral hours on the net, I found a contradiction of results. 60% say on the upper hose and 40% say on the lower hose. The latter of the two requires a great deal more labor and disassembly of the cooling system, removal of drive belts and at the least the removal of the power steering pump to access the water outlet/thermostat housing. I hope you understand my hesitance in jumping back into the fix without some verification first.
Score 3
1 Comment
Excellent job, who would have thought :-) now all you have to do is convert your comment to an answer and accept it. This way we know your case is closed. Great job in getting it done.
by
Add a comment
Chosen Solution
Thanks oldturkey03, I already have the manual and it does'nt specify the "UPPER" hose. Alas, after wrestling with the p/s pump to allow access to the bolts securing the lower water inlet, I removed the "BOTTOM" radiator hose & water inlet. It was there that I found my thermostat. Thanks again for your assistance. In case it help others to avoid the levels of research I so enjoyed, here are the particulars of my truck.
1997 4x2 XE KING CAB
134hp 2.4liter SOHC 4cyl
Engine Type: Ka24e
Hope this info comes in handy
Score 3
2 Comments:
You are correct, and sure wish i would have seeen this rather than all the Top Hose info i found at first :(
by
Thank you for sharing this. i was perplexed when I had the same problem on my '96. at first I thought someone had removed the thermostat, but then i found that the new one was too large to fit where i have found the thermostat on the rest of the 20 + vehicles that I have owned.
by
Add a comment
Most Helpful Answer
Just checked the manual on the 1997 D21 engine. The thermostat is in the housing that the UPPER radiator hose connects to.
I have downloaded the complete SERVICE MANUAL for your truck on my file storage. You are welcome to download it right here . It is over 1000 pages. All you ever wanted to know about your Nissan. No,its not some sort of scam or free money from Nigeria thing....:-) good Luck
Score 4
7 Comments:
+ very nice research
by
Thank you Sir, hope it will help out to get the Nissan going again :-)
by
-oldturkey03
Wow, I did the same exact thing. The Haynes repair manual told me that the thermostat was connected to the top radiator hose. It's actually connected to the bottom radiator hose for my model.
Do you think you could post that manual again, I just bought the truck, and I'm fixing it up a bit. I would really appreciate it.
Kevin
by
@Kevin, click on the new link. It should be back up. Good Luck.
by
-oldturkey03
I know it has been better than 5 1/2 years ago, but i could sure use the manual you posted here before. If you are still around and still have it, would you mind posting it one more time? I would greatly appreciate it. T.hank you.
curtis
by
Show 2 more comments
Add a comment
I just changed the tstat on a 97 Nissan pickup king cab with a 2400 12 valve engine and went under the assumption that everyone was right about the top hose housing being the location and it is not! It was in fact in housing where bottom hose from radiator meets the block which is in the front center engine block and I had to pull the radiator just to hope to be able to access it! It was not easy to change at all but was able to do so with some time and only removing the radiator but I wouldn't suggest someone without much knowledge of engines doing so. Oh I also need a gasket for the top hose connection I broke loose now as well...hope this helps someone!
Score 1
1 Comment:
It was the 2.4L...forgot to mention that
by
Add a comment
I diagnosed a missing or open thermostat on my recently purchased Nissan XE by checking for water flow on cold startup. I saw that the engine was running cold. I look for the thermostat housing in a typical place, at the upper radiator hose connection to the block. By the size of the opening I could tell that the thermostat either had to be very small or located somewhere else . So I bought the thermostat before I did anything. The size of the thermostat verified that it would not go there. That's when I went online and found this site. So thank you for the information.
Score 1
Add a comment
follow your top radiator hose to your engine! its realy the same on any car!
Add a comment
Where is the t-stat located on a 1996 2.4 Nissian Pickup engine?
Add a comment
Thermostat is on the bottom hose right beside water pump under power steering pump my truck is a 1996 nissan XE exstended cab with 2.4 engine
Add a comment
Add your answer
nevadaman2002 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 34
All Time: 18,213
