Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Replacement of Harddrive: SSD with SATA 3
Hey there,
I have read that the new OCZ Vertex3 SSD will have an SATA 3 6.0Gbit/s connection. Does the SATA controller of the new MacBook Pro series (8,1 8,2 8,3) supports SATA 3?
Thank you for your support!
Sebastian
Add a comment
Chosen Solution
This article should give you all the information you need on Macs and support for SATA 3, USB3, 6 gbps and SSD support: http://www.stationstops.com/2010/02/17/a...
Score 2
Add a comment
I believe that the harddrive will work regardless if the SATA controller is SATA 3 or not, it just won't at its full speeds. That SSD will still provide a very nice performance boost though. SATA 3 is backwards compatible
Don't forget to mark whichever answer satisfies your question, if any.
Score 1
2 Comments:
Hi Skippy722,
Thank you for your reply.
The performance of a SSD drive with SATA 2 is quite nice. I have currently installed a Vertex2.
But I was wondering if I can reach the full speed of 550MB/s with a Vertex 3 SSD via SATA 3 in the new MacBook Pro.
by
Via SATA3, yes you will see full speeds, in a perfect world. There are other issues, so those numbers are just the absolute maximum that the drive can do.
by
Add a comment
The article cited by mayer is about last year's notebooks. Apparently the HDD shows as SATA 3, but not the DVD drive (that may be a SW limitation; a similar situation happened with SATA 2)
http://forums.macrumors.com/showthread.p...
Add a comment
Hi,
My macbook late 2009 has sata-2 hard drive interface. I got a SSD SATA 3, Kingston Hyper SSD 120. Will it work if I connect the ssd sata3 with the sata2 connector inside my macbook?
Thanks
Adriel.
Add a comment
Add your answer
Sebastian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 24,741
