Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
Power shorting out when turning on iMac
My 2.8Ghz 2008 iMac shorts the power when I turn it on, could this be the power supply or the cable? This recently happened, before that it was working fine. I don't have an other cable to test it with, so I'm relying on you guys, because the PSU is still about 100$...
Thanks in advance,
Tristan
Add a comment
1 Answer
Chosen Solution
So lets see if I understand this correctly: Your fuse panel breaker trips when you try to start your system.
You have the systems AC cord directly plugged into the wall outlet and the wall outlet is a dedicated 20 Amp (3 pronged outlet) service for your computer. If not disconnect (turn off) all other devices that also share the same breaker line (other outlets and/or lights).
Again, as soon as you press the power button on the system Bang! The breaker pops correct? If thats the case you've isolated the fault to the power supply within the system.
Score 1
Add a comment
Add your answer
Tristan van Triest will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 447
