2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
Erratic power short when KB/case touched
Apple MacBook Pro "Core 2 Duo" 2.5 15" (08) Specs
Identifiers: Early 2008 - MB134LL/A - MacBookPro4,1 - A1260 - 2198
MBP15", silver KB. Been dropped a few times; only proximal results are a single green line on display and several dents in case. Warranty expired.
Gradually it began having a problem where, if touched "wrongly", it would suddenly power off completely. No warning, nothing, just total immediate power off.
This grew worse over time. There was no clear sensitive spot - could be somewhere on base, any place on KB, monitor tilt - pretty much anything MIGHT set it off. Being placed on a lap vs. desk seemed to improve this slightly.
Sudden poweroffs caused some s/w issues, e.g. preferences lost (presumably had been treated nonatomically and so got wiped along with RAM). Otherwise HD seemed fine. RAM test clean.
Case shake revealed no rattle. Systematic probing showed no consistently sensitive spot. Poweroff could occur anywhere from immediately after power on to several hours in use. System temperature had no effect, happened during cold boot too.
Popping top case revealed no obvious defects or shorts. Disconnecting HD, DVD, battery had no effect (except of course w/out HD boot would not progress past attempt to load OS). Same issue running from battery, plug, or both. Very light touch on any part of PCB could set it off... or not, no real consistency.
I've not been able to determine the root cause yet. Obviously an electrical short somewhere, but can't tell whether internal to PCB or maybe PCB touching e.g. some part of metal case in bad way. Haven't yet tried pulling PCB out of case.
Questions:
1. What should I do next to diagnose/fix?
2. Guesstimate % chance of successful fix.
3. If dead, what's the best way to recover money from it on parts? E.g. can I give to someone (for a cut) to part it out for me? What parts are worth selling on ebay?
Obviously will dump & wipe the HD before doing so.
Thanks!
Score 1
2 Comments:
What's a PCB? Is that PC talk? I changed your machine ID to the correct one.
by
PCB = Printed Circuit Board. Standard computer hardware terminology.
by
Add a comment
1 Answer
To clarify, you never get this prompt randomly, correct? This would rule out a faulty power button.. is there a dent on the top right side?
Have you tried to use a USB keyboard/mouse, or getting one of those incase plastic cases? And when you just don't touch it at all (USB kb/mouse) it won't restart, correct?
7 Comments:
Never seen that prompt. Power button does function to turn it on. Haven't tried USB kb/m, don't have plastic case but if it's dead then it's kinda too late for that. :P
If you "don't touch it at all" it still does restart randomly sometimes. I've had it restart without *anything* touching it other than the desk it was on. Not really interested in partial solution that requires babysitting it - if it can't be used as a laptop it's mostly useless to me except as scrap to sell.
Dents - right: 1 between ethernet and USB jacks; front: 1 in middle of DVD slot, 1 ~2" left of the IR receiver; left: 1 between magsafe & USB.
by
Oh wait! I thought you had a unibody! What is the model of the Macbook Pro you have? I suspect its the top case but i'm trying to make sure that it is... Let me try something on my macbook
by
Try checking Console to see whats the reason for the shutdown.
by
Serial: W88121RWYK0 (15" Early 08). Right now it's unable to even complete a full boot because power cuts out, however I really doubt console would know anything because symptoms clearly point to a physical, electrical short causing it - not a software issue. For instance, it can happen when still loading BIOS.
by
Also as I said, symptom is present AFTER removing the top case.
by
Show 2 more comments
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,412
