Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Question Closed
Touch screen does not work
I replaced the original touch screen after ripping the digitizer ribbon when I opened my iPod Touch 2g for the first time to replace the battery. However, even with the new digitizer, the touch screen will not work, but the home button does. I wonder, do I need all the little screws screwed back in place behind the battery as well as in all other places? Or should I try and get another replacement digitizer as I've seen in other posts that said they had to make multiple tries from different vendors from ebay?
Add a comment
1 Answer
You shouldn't need all the screws in-- if the cable is plugged in, it should be working (the button is a different system, so it might work even if the touch does not). I would suggest trying a different digitizer, it might just be a faulty one.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,648
