does the A1052 support 1Tb hard drive
Does the A1052 support support 1Tb drive?
Here's how to do it but it uses and ATA drive not an SATA and I don't know where you can find such a drive. It will however, that the 12 mm thick drive.
Search for a ATA100 (IDE) 5400RPM Hard Drive or better
Here's a PDF on doing it:
http://web.archive.org/web/2007011803443...
here's the standard guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Will the A1052 support an external SATA drive that I can use as a startup drive?
Sure if the connection is a USB to SATA.
Pre-Installed MacOS: X 10.2.7 Maximum MacOS: X 10.5.8
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 94
