Model A1318 / 32 or 64 GB capacity
299 Questions View all
Why is my internal speaker so low?
I have the volume all the way up, volume limit set to off and all settings seem to be right. I restored in iTunes in dfu mode and set up as new iPod. Is there anyway my full body protector could be causing this (Zagg skin)
Score -1
Add a comment
Most Helpful Answer
Rob,
The skin is going to cause your volume to be slightly less that it already was. Those tiny speakers are just not built for volume. Try removing the skin and see if you are back up to normal volume. I use a hard case on mine as it resonates and sound passes through the end at the docking port. It still muffles it a bit but I can hear it for reference. Other than reference I use the ear buds so really don't have the speaker in use too much. Please let us know what you find out.
Score 1
Add a comment
My iPod Touch 3rd generation speakers haven't worked ever, not even when I got it. When I turn it all the way up it makes a weard noise and if I turn it up to volume 1 or 2 it makes noise 3 = NO NOISE?!? HELP ME.. What sould i do?
1 Comment:
Joe,
You need to post this as a new question or no one will see it except me and Rob E. Post as a new ? under the correct model and gen and let us know if you bought it new or?
Thank you,
Marc
by
Add a comment
Add your answer
ROB E will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,090
