5-Inch Portable Vehicle GPS with Lifetime Maps and Traffic (Discontinued by Manufacturer).
5 Questions View all
Why does my 2557 shut off?
My Nuvi 2557 LMT frequently shuts off, particularly when traveling at low speed. The original power cable broke and I am using a generic power cable. Might there be a cable issue or has this Nuvi reached the next of it's serviceable life?
Add a comment
1 Answer
Chosen Solution
Is the port where the cable connects to the GPS loose at all It could be an issue of broken solder joints at the port and if you wiggle the wires around you get a connection . Inspect the port for how well it connects look closely inside the port forr lint or dirt and if you do need to clean the port use a toothpick are plastic pick . Dont use metal as it can break the port. Next check your cable as well could be a problem your new cable . How long will you GPS run without being plugged in , it may need a new battery. This guild will help with replacing the battery
Garmin Nuvi 2557LMT Battery Replacement
Hope this helps
Score 3
Add a comment
Add your answer
MountWarnerVineyards will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 169
