Garmin Nuvi 2557LMT Battery Replacement
  1. Garmin Nuvi 2557LMT Battery Replacement, Garmin Nuvi 2557LMT Disassembly: step 1, image 1 of 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Battery Replacement: step 2, image 1 of 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Battery Replacement: step 3, image 1 of 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Battery Replacement: step 4, image 1 of 2 Garmin Nuvi 2557LMT Battery Replacement: step 4, image 2 of 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Battery Replacement, Battery: step 5, image 1 of 1
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Battery Replacement: step 6, image 1 of 1
    • Pull the battery-motherboard connector away from the motherboard.
2 other people completed this guide.
2 Comments
On my Nuvi 2557, the silver name bezel is part of the front cover - it does not separate. I just split the case as shown.
The battery connector pulls out perpendicular to the pc board, and you re-insert it by aligning and pressing down against the board.
john horn - Reply
Would this apply to the Nuvi 2555LMT?
Bill Hines - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,219
